Hello Guest it is June 10, 2026, 02:29:04 AM
Author Topic: Migrating from parallel port to SS  (Read 12497 times)
Offline mikie
  •  18 18
« on: February 17, 2009, 01:33:38 AM »
I loaded SS today on my laptop and connectivity is as expected (Setup is a per instruction manual)
Now, as my brain is in low gear most of the time, I think i have missed how SS works.
My current configuration for Mach3 is via the parallel port.
What is it that I need to do to get SS to work instead of the Parallel Port?
/Michael
Re: Migrating from parallel port to SS
« Reply #1 on: February 17, 2009, 01:20:07 PM »
Just connect the parallel cable(s) to the SS and configure a few things like frequency in the SS config and all should work fine :)
Offline Pythagoras
  •  93 93
  • a² + b² = c²
« Reply #2 on: February 20, 2009, 06:19:27 AM »
Hey Mike, I got mine to work, the mistake I was making was pretty embarrassing. I was counting the ribbin wires as 12345 etc
Benny
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c).     a² + b² = c².
Offline mikie
  •  18 18
« Reply #3 on: February 21, 2009, 03:07:45 AM »
Fantastic, thought it would be something straight forward.
Now to get mine going tomorrow
« Reply #4 on: June 16, 2009, 07:56:52 PM »
what is the advantage of using smooth stepper instead of the c11 bob with the parallel connection?. the usb smooth stepper does not support backlash comp. and there are many issues loosing communication, some of which i have begin to experience.
