Hello Guest it is June 11, 2026, 07:39:14 PM
Author Topic: Write Wizard - No code output  (Read 40279 times)
nitromethane1721
« on: July 21, 2006, 09:41:58 PM »
Can some one give me a crash course on using it?  Can't get it to output any code at all.  Must not have something set correctly.
William in MN
nitromethane1721
Re: Write Wizard - No code output
« Reply #1 on: July 21, 2006, 10:43:51 PM »
Noticed that the wizard will work just fine when running in Mach3 - Mill profile, but when I try using the profile I created, "Taig Mill" it fails to create code.
Is there a quick way to switch between profiles without closing and re-launching?
William in MN
« Reply #2 on: July 22, 2006, 08:50:12 AM »
Copy the Macros from the macros/ Mach3Mill Directory  to the macros/TagMill directory and you should be good to go :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: July 29, 2006, 02:57:50 AM »
hiya
ive attempted to use the write wazard. but i am unable to output as g-code. do you know what i may be doing wrong
rgds dave
« Reply #4 on: July 29, 2006, 04:38:24 AM »
Dave answered your PM, hope it helps.
« Reply #5 on: June 17, 2011, 08:27:31 PM »
I have Tormach 1100 and I can not get the write wizard to work or out put G code NEED HELP.
Thanks Carlbeo
andrewm
« Reply #6 on: June 20, 2011, 08:32:03 AM »
If you don't have a license for the newfangled wizards, they wont output any gcode. When you try to post code do you get a unlicensed wizard error in the GCode window?
« Reply #7 on: June 20, 2011, 10:24:58 AM »
Andrew
   When I click on post code it goes to mach3 and not a thing no code. It goes to the previous code.
   Thanks Carl B
andrewm
« Reply #8 on: June 20, 2011, 10:28:39 AM »
Do you have a license for the newfangled wizards? They are not included with mach3 like the others.
« Reply #9 on: June 20, 2011, 12:38:42 PM »
Andrew
   I guess not it came on the machine I bought the machine 2nd hand . How do I get the license?
