Hello Guest it is June 09, 2026, 11:34:47 PM
Author Topic: OEM Buttons Description  (Read 25624 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: OEM Buttons Description
« Reply #10 on: November 26, 2006, 11:14:30 PM »
Hi, All
Is there a OEMCODE # for "Zero A Encoder 4", I've looked in the wiki.
Thanks, Chip
« Reply #11 on: November 27, 2006, 08:52:24 AM »
There is not a call for that... Is there an OEM code that you like for one of the other axis?
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #12 on: November 27, 2006, 02:13:36 PM »
Hi, Brian
Yes, for encoder 4, there is an encoder 4 DRO, just couldn't find the Zero button OEMCODE for it.
If it's a big hassle, It seems to reset by clicking and using keyboard or pop up calculator window.
Thanks, Chip
« Reply #13 on: November 27, 2006, 02:43:00 PM »
should be 1011 :)
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #14 on: November 27, 2006, 07:37:42 PM »
Hi, Brian
Thats not the Encoder 4 Zero button, OEMCODE #, working on a screen.set for one of the users hear, maybe it will get added later.
The reset, by clicking and using keyboard or pop up calculator window, Works Fine.
Thanks Chip
« Reply #15 on: November 28, 2006, 07:12:46 AM »
I see :) If you can tell the OEM button number that will do what you would like but on an other axis that will make it soI can code it in. So lets say it is the x axis and you would like to zero it out, what OEM code are you using?
Brian
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #16 on: November 28, 2006, 09:40:02 AM »
Hi, Brian
Just using Encoder 4 input for a 2nd Z axis, Spindle on a Bridgeport for manual  position Reference see below.
The 3 encoders on Settings page, X Y Z are used, in Ports-pins Encoder/MPG's X Y Z (4) are available.
Just no Zero Button for 4'th.
Zero X Encoder 1   133
Zero Y Encoder 2   134
Zero Z Encoder 3   135
Zero A Encoder 4   ??? OEMCODE, it's not listed in Wiki
Thanks, Chip
     Re: Bridgeport extrak retrofit
« Reply #6 on: November 27, 2006, 07:46:53 PM »
   Reply with quote Modify message Remove message Split Topic
Hi, Rogerbsstt
Disregard my earlier Post on this, Hears a better way, I Think.
Hear is a screen .set I modified just a little, You need to set under, config, ports & pins, Encoder/MPG's, Encoder 4 to your A,B output to this.
Enable Encoder 4 Set A-port to 1, B-port to 1, then use 2 unused pin's on port 1 for your A, B, encoder input pin's,
Pin's 10-13,15 are the only one's you can use, Set the Count Unit's to 1000 - 4000, probably, 4000 to calibrate for .001 div., Click on Apply then OK.
Just make sure there outputs are no more than 5 Volt's.
Under Operator, Click on Auto/Calculator this will give you a Pop-Up window to Zero it, it works on other items also really nice.
To Zero the Quill Z click on DRO, Use,  Calc. Window to edit, You can pre-set to most any value.
Or use keyboard  to edit, Don't forget to hit enter Key.
Don't think I left anything out.
Oo, copy the set file to your Mach3 Folder, load-it give it a try.
Helps, I Hope, Chip.
« Last Edit: November 28, 2006, 09:44:50 AM by afn09556 »
« Reply #17 on: November 28, 2006, 11:05:51 PM »
Just checked and there is no OEM code for that
sorry
Brian
www.machsupport.com
