Hello Guest it is June 09, 2026, 06:27:59 PM
Author Topic: Mach3 will not run?  (Read 9409 times)
Mach3 will not run?
« on: January 25, 2009, 12:50:24 PM »
Hi there,
I used to run mach2 on a milldrill several years ago. I had no problems then. I got out of home cnc for a while and want to start again. I used to run mach on my laptop just for checking programs before sending to the CNC PC, as I know the laptop is not good for the CNC side of things. nayway, my XP SP3 laptop (HP DV8000) wont run Mach2 or Mach3. They install fine, but when i load either program i get the unexpected application error dialog box. I tried msconfig w/ minimal drivers but the sam eproblem exists.
Have others had this problem? If so, a solution would be greatly appreciated!
mlinder
  •  9,356 9,356
Re: Mach3 will not run?
« Reply #1 on: February 16, 2009, 07:11:15 AM »
Hi Mlinder,
I know it's perhaps not what you want to hear but the easiest solution, I think, would be to use a PC rather than a laptop.
« Reply #2 on: February 16, 2009, 09:00:51 AM »
mliner,
Did you do a reboot after installing Mach3? It should run the program. Now as far as running a machine from that laptop that's a different problem , maybe.
