Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2012, 02:54:16 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Smithy 1240 CNC and enclosure
Pages:
1
2
3
4
Go Down
« previous
next »
Author
Topic: Smithy 1240 CNC and enclosure (Read 5473 times)
mvcalypso
V4 Screen Contributor
Offline
Re: Smithy 1240 CNC and enclosure
Reply #30 on:
January 27, 2009, 11:09:46 PM »
re the possible servo conversion... I'm just in the thinking stage on that one.
My design would be driven by the equipment I already have. I have a set of motors and encoders that I used on a prior knee mill that I converted to CNC. They are MCG DC servo motors, 2 850in-oz (X and Y) and one 1100 in-oz (Z).
First issue is that the motors I have are all N34 mounts and all the smithy mounts are N42.
Smithy needed the N42 for Z and then decided to use all N42 to save SKUs - they told me early mills were N34.
The Smithy N42 mounts are essentially mechanical interfaces that convert form a bolt pattern at the machine/table end to a N42 mount. They are deep enough to house the couplings that are used between the Steppers and the ball screw shafts.
Smithy made a couple of servo driven 1240s - but they direct couple the servos to the shafts - I'm not surprised they didn't find that satisfactory. I'm include in the design in a belt drive reduction to keep the servos in the desired RPM range (again I'd use the pulleys and belts I have). This does not look too hard on X and Z, but Y is a bit more of a challenge as the Y motor is under the column arch casting. So I'm thinking that a shaft and bearings to extend the Y shaft out behind the casting would be needed... that then involves clearance issues between the casting and the rear panel of the cool catch system that I built the enclosure on top of....
I expect this so be a longer term project - I thought about it some prior to purchase, and I'm convinced it's doable, but it's also not an immediate priority for me. Since the steppers do work, it's easy to put this off and use the mill as is for higher priority projects.
dgowland
Active Member
Offline
Reply #31 on:
February 05, 2009, 06:31:34 PM »
So how is the mill working so far ? Have and part pictures to show the finish ?
SMITHYCNC
Holding
Offline
Reply #32 on:
February 20, 2009, 09:46:12 PM »
HELP
I have a early style Smithy 1240( Servo 4 speedTransmision) Please help setting up Mach3 I have no paperwork on this mill A screen print of the pin set up would be GREAT . It now has emc2 on it no AXIS setup . I purchased it USED Please someone HELP . Thanks
edvaness
Active Member
Offline
Reply #33 on:
February 20, 2009, 09:56:43 PM »
Smithycnc ,
Does the EMC not work ? EMC runs on Linux os . If you want to run Mach, you'll have to install on win 2000 , or xp. Preferably a pc tower.
Then check out the manuals and videos on the support tab at the top of this page. If you need more help , come back to this forum.
Ed
Ed VanEss
Pages:
1
2
3
4
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
