Hello Guest it is June 10, 2026, 02:41:43 AM
Author Topic: Mach3 Dev. Version 1.90.065 w/grex bugs.  (Read 13141 times)
Offline nicad
  •  40 40
« on: July 19, 2006, 11:03:48 PM »
I don't know if this is the right place for bug reports??
just installed Mach3 Version 1.90.065 w/Grex on a 4-axis system.
If I zero the A axis, all is well.
If I zero the Z axis, A axis will set to a huge number (machine ABS).
If A axis is zero'd and I zero the X or Y axis, Z axis will set to a large number (machine ABS) AND A axis will set to a huge number (machine ABS).
If A axis is left at the huge number and I zero the X or Y axis, all is well.
Happens on all screens.
Also, some of the images for the buttons on the "program run" screen are corrupt. The ESTOP on all screens, if flashing, is also corrupt.
Is it just me?
That is all so far. :)
Re: Mach3 Dev. Version 1.90.065 w/grex bugs.
« Reply #1 on: July 22, 2006, 08:51:44 AM »
The Aaxis thing shoudl be fixed if you downlad the newest version :)
The E-Stop button thing... we will have to look into that.
www.newfangledsolutions.com
www.machsupport.com
