Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2012, 02:25:37 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
SmoothStepper USB
(Moderator:
Warp9TD
Does Smoothstepper smooth acceleration?
Pages:
1
Go Down
« previous
next »
Author
Topic: Does Smoothstepper smooth acceleration? (Read 2396 times)
tahustvedt
Active Member
Offline
on:
January 12, 2009, 04:53:06 PM »
Does Smoothstepper smooth the acceleration like Quantum does to eliminate the jerks? I got the impression that it did in the Quantum forum when someone said Quantum is no longer necessary now that Smoothstepper is available.
Last Edit: January 12, 2009, 04:55:08 PM by tahustvedt
Active Member
Online
Carnoustie, Scotland
Re: Does Smoothstepper smooth acceleration?
Reply #1 on:
January 12, 2009, 05:27:05 PM »
No, its just the same as PP (just cleaner and faster), well as far as I know anyway
Global Moderator
Offline
Reply #2 on:
January 12, 2009, 05:50:01 PM »
Someone please correct me if what i say is wrong. Thought that in Quantum, the acceleration curve was not linear
like you currently seen in the motor tuning graph. So in quantum, you would have a more gradual approach on decel and accel towards a velocity. In that case even without the Smooth Stepper the machine would be smoother running. Probably more so at higher speeds. A pulse is a pulse, and if they can be delivered better, as Hood said, you can run faster without missed steps. With in reason.
Active Member
Online
Reply #3 on:
January 12, 2009, 05:58:37 PM »
Quantum uses S Curve acceleration, not sure whether you can use the SS with quantum.
tahustvedt
Active Member
Offline
Reply #4 on:
January 13, 2009, 02:02:40 PM »
Ok. I'm using Mach3, BTW. So it will actually let me run faster than what I can achieve with just Mach3 and a direct LPT interface?
Sorry if I'm asking stupid questions, I didn't know what it does other than what's explained about the function in the SS manual, which didn't make sense when I read the comment in the Quantum forum.
ger21
Global Moderator
Offline
Reply #5 on:
January 13, 2009, 05:31:21 PM »
The smoother pulses
may
make your motors run smoother, which
may
make them go faster, but unless Mach's kernel speed is limiting your speed, the Smoothstepper doesn't do anything that would give you more speed.
http://home.comcast.net/~cncwoodworker/2010.html
Active Member
Online
Reply #6 on:
January 13, 2009, 06:02:54 PM »
The benefits of the SS are as has been mentioned the smoother pulse which may allow faster speeds from steppers but no guarantee there as it would depend on how nice a pulse your PP was putting out.
It can pulse up to 4MHz compared to the PP max of 100KHz (more likely 45KHz) As Ger said if the pulse rate from the PP would limit your potential speed then the SS is a good move. A situation where that would be true is if like my lathe the servos have 2000 count encoders (8000 pulses per rev) , with the PP you would be looking at 1.687m/min max (45KHz kernel 5mm pitch screw 1:1 gearing) with the SS the max would be 150m/min. Obviously the motors top speed would be the limiting factor here and I dont get anywhere near the SS potential
Another benefit is the pulseing is taken away from the computer so that frees up CPU and also the issues with on board graphics and laptops (although not a 100% guarantee, it seems to be the case)
The bad points about the SS are it costs $150 , not a huge amount, but if you cant benefit from any of the above its probably not worth it.
Last Edit: January 13, 2009, 06:04:55 PM by Hood
Global Moderator
Offline
Reply #7 on:
January 13, 2009, 06:07:04 PM »
tahustvedt,
Can only tell what i have experienced from testing and using the SS as compared to running off the PP.
This posting is from my experience only for my equipment, can't speak for anyone else, shouldn't be taken as
endorcing a product, and shouldn't be used to confince you of anything.
Using the SS i can run my machines at a higher velocity. It solved the problem of a poor pulse signal out of the PP which was due to on-board graphics. If you want speed, then have your system favor it or compromise speed to torque as you wish to accompliish what you want to do. As far as speed, the rapid increase was at least 2x
and up to around 4x with out skipping. Now i could get more speed if i bumped the voltage up and get more torque if the current settings were higher, thus POWER can be had in other ways. Big woop! I don't care to tear up my machine to impress anyone!
tahustvedt
Active Member
Offline
Reply #8 on:
January 14, 2009, 11:55:19 AM »
Ok, thanks.
Sheldon Dingwall
Active Member
Offline
Reply #9 on:
July 01, 2009, 06:39:35 PM »
I'm not looking for more speed, but my machine seems to have unnecessary vibration. Can I assume that smooth stepper can help?
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
